Tho_Ge's avatar
Tho_Ge
5 years ago
MAX10 ADC offset issue
We are using the internal ADC of a Max10 (10M50) to monitor some voltages.
For a reference voltage of 2.5V the offset error should be about +/- 5mV (offset error and drift 0.2% FS, prescaler disabled)
For testing purposes we have recorded 15 voltage steps in the range of 0.1V to 2.4V.
With these values we calculated the offset for the ADC, which gave a result of -8.45mV.
We repeated this Test with other voltages (3.3V to 5V via a voltage divider).
Each of the measurements resulted in a higher offset value as expected and always negative.
Have you seen similar behavior?
  • EngWei_O_Intel's avatar
    EngWei_O_Intel
    Hi Thomas
    I hope you are doing well. Since we don't receive any feedback to the thread, we will transition the thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Eng Wei
    EngWei_O_Intel
    Hi there
    Are you using a development kit or designing a board with Max 10?
    If you are designing a board, have you got the schematic reviewed especially on power and Vref pins? Have you seen similar issue if running the same test on the development kit? Also, please refer to section 3.3 of the userguide for board design guidelines.
    Also, can you check if your design compilation having any Critical warning related to ADC?
    Eng Wei
    • Tho_Ge's avatar
      Tho_Ge
      yes, there are a total of 28 critical errors relating to the ADC. Here is an example:
      "Critical Warning (16248): Pin I_FLT_SWITCH_N_AMP2 is placed too close with ADC pins. I / O pins place too near to ADC pins will cause performance degradation on ADC sampling. Please reassign the pin assignment further away from ADC pins and re-run the compilation again. File: "
      The signals that are close to the ADC inputs are mostly static signals that are typically high or low.
      Our design uses all IO ports, we cannot leave pins unused around ADC inputs.
      Thomas
        EngWei_O_Intel
        Hi Thomas
        And yes, please review all the Critical warning and you can suppress those Critical Warning with IO_MAXIMUM_TOGGLE_RATE set to 0, according to the actual behaviour of those pins.
        Also, are you using external Vref? Have you tested with internal Vref?
        Eng Wei
