tyassin
9 months agoMAX10 (10M02SCU169I7G) - VREF pins
Hi, I have a single supply device with 3.3V. I have to clarify my undestanding of the VREF pins. They seem to have a dual purpose on this device: Can provide another reference voltage than the no...
- 9 months ago
VREF pins are used for voltage referenced I/O standards like SSTL, e.g. for DDR RAM. If not needed for this purpose, they are available as regular IO pins. Treat unused VREF pins like any unused IO, e.g. activate weak pull-up to avoid floating.
Regards Frank
tyassin
9 months agoI see.
Thank you very much for explaning.
Br. Thomas
- AqidAyman_Altera9 months ago
Yes, Frank is correct. You can refer to the Pin Connection Guidelines for MAX 10.
https://docs.altera.com/r/docs/683232/current/max-10-fpga-device-family-pin-connection-guidelines/differential-i/o-pins#:~:text=or%20GND.-,VREFB%3C%23%3EN0,-Power%2C%20I/O
