Max10 - Quartus: no dual boot option avaliable
- 4 years ago
I try myself with the same device and I couldn't see dual options either. Then I search a bit an found it is because 'SC' series of max10 don't support dual features. Probably because of lack of flash elements. The relevant pictures attached below. As you can see SCs very few flash memory compare the others.
Hmm, what version of Quartus is that? Very strange that the option is not there.
As for the config_sel question, that pin is only used to select the initial image to use. After initial device programming, your control mechanism, like a Nios processor, can be used to switch the image.
- fogl4 years ago
I am using Quartus Prime Version 19.1.0 Build 670 09/22/2019 SJ Lite Edition. It is installed on linux machine.
Klemen
- jozephka994 years ago
Contributor
Did you select your device properly? And for config_sel pin, like @sstrell said if you power off and on your device it configures from config_sel pin's selection. If you gonna implement a remote system upgrade you should upgrade the CFM section regard to config_sel pin's logic level so when you power up again it begins from your upgraded image.
- fogl4 years ago
I selected the device with Assignments->Device menu. Please see image attached. The Compilation Report also shows the same device after compilation process.
Is there also some other way to select or to check if the device was properly selected?
