Randrian's avatar
Randrian
3 years ago
Max V SEU mitigation
Dear Sirs,
I plan to use MAX V CPLD for an application exposed to ionizing radiation.
Do you have any papers about MAX V SEU testing and results, for both CRAM (configuration RAM) and CFM (configuration flash memory)?
Does the device implement SEU mitigation like CRC or someting else? I will not use TMR (triple modular redundancy) technique.
Randrian
  • WZ2's avatar
    WZ2
    Hi Alexandre.
    I just further checked documentations.
    The estimated Data Retention hours for MAX II and MAX V are the same, because they used the same FLASH memory process technology.
    Thanks & Regards,
  • lixy's avatar
    lixy
    Hi Alexandre,
    Sorry I could not find this data you mentioned.
    There's only "Erase and reprogram cycles" listed in MAX V Datasheet and the reliability monitoring report.
    Thanks & Regards,
    Xiaoyan
    • Randrian's avatar
      Randrian
      Hi Xiaoyan,
      Could you tell me if the data retention should be the same as Max II?
      Alexandre
  • Randrian's avatar
    Randrian
    Hi Xiaoyan,
    What about the flash data retention, how many years for 12hours use per day?
    Alexandre
  • lixy's avatar
    lixy
    Hi Randrian,
    Any further questions?
    Xiaoyan
  • lixy's avatar
    lixy
    Hi Randrian,
    Yes. MAX V and MAX II used the same process technology, so the FIT rates are the same.
    Xiaoyan
  • Randrian's avatar
    Randrian
    Hi Xiaoyan,
    For my design, I will replace a MAX II-based old design by MAX V. Could you please confirm if the FIT rate of MAX V device is the same as the FIT of MAX II?
    Alexandre
  • lixy's avatar
    lixy
    Hi Randrian,
    Here's currently no documentation for MAX V SEU mitigation. Also, CRC is not used in MAX V.
    If you would like to know the FIT rate for MAX V device, you can log in Resource & Documentation Center (intel.com) with NDA and search for "Reliability Monitoring" report.
    Also, there is an "SEU FIT Report" in Quartus, which is license-required .
    Thanks & Regards,
    Xiaoyan
