Randrian
3 years agoMax V SEU mitigation
Dear Sirs,
I plan to use MAX V CPLD for an application exposed to ionizing radiation.
Do you have any papers about MAX V SEU testing and results, for both CRAM (configuration RAM) and CFM (config...
lixy
Contributor
3 years agoHi Alexandre,
Sorry I could not find this data you mentioned.
There's only "Erase and reprogram cycles" listed in MAX V Datasheet and the reliability monitoring report.
Thanks & Regards,
Xiaoyan
Randrian
3 years agoHi Xiaoyan,
Could you tell me if the data retention should be the same as Max II?
Alexandre
