Max V 5M80ZE64C5N examine / Verify Failure
I assumed that if the security bit is set, the check box should be grayed out, which it is neither with the programmed nor with a new chip.
This makes me think - something is wrong here.
with this board everything is unusual.
I have to try this again, but I need some file that I can load to test how it looks with and without security bit.
I have no idea of the programming or creation of a simple file.
I just wanted to clone a chip and have only read and learned so far.
Can you help me with a very simple test file in which maybe just something is in it without switching an output - the board can die - my risk -
it's only about testing the basic function
1 Write a file
2 File Examine
3 File verification
and repeat everything again under security bit set.
I would like to test so whether this works on this board with a clean file
