14 years agomax number of bit of a multiplier in statix III
Hi, I am implementing a DSP algorithm on Stratix III device. Internally, I am using 16 bit and this bit width does not give a right calculation. I increased upto 32 bit but still same. ...
14 years agoIn most applications 16 bits x 16 bits is fair enough. In the most demanding cases I can say 32 or so. The question should be what are you comparing with. If you use floating point tool then why not change your model to fixed point.
