17 years ago
Max Nios input speed?
What is the max speed the data can be feed into the Nios and then sent out on the ethernet?
Thank you in advance.
    Yea i might have to I think.
    Currently I send the data to the Nios and then becasue I am using one of the multiplexer channels as a header I am using this as a refreence for the server to then write the data to files.
    You're right, that is very slow. I can tell you that I'm able to achieve ~40Mbit/s over the ethernet. I've also been able to do ~300Mbit/s using USB. So you are nowhere near the physical limitations.
    So how have you got your tasks prioritized in uCOS/II. Is it possible that your task that samples the data simply isn't running frequently enough.
    My personal approach to this would be to write a little hardware module to sample the data and store it into the FIFO, then have the NIOS come and grab large chunks of data and send it off.
    Jake
    I am sending the output from a multiplexer to the Nios. At the moment I am sampling the the multiplexer at 100Hz / 8. (8 Channels)
    The Nios is then connected to the PC via ethernet, using the mirco os or whatever it is called. I have two sockets open, one to send data and one to recieve commands.
    When tryign to increase the sampling rate, >200Hz my server on the pc crashes becasue data is missing on the input, i guess being lost in the Nios.
    Any ideas? I guess my limited sampling rate must be 200Hz. Is this correct as seems slow?
    This is not a simple question. There are so many ways you could do this that nobody can give you a simple answer. Do you have a decided upon implementation? We might be able to give you an estimate on how fast your implementation will run. How are you bringing the data into the NIOS? What TCP/IP stack are you using?
    Jake
