17 years agoMax Nios input speed?
What is the max speed the data can be feed into the Nios and then sent out on the ethernet? Thank you in advance.
17 years agoThis is not a simple question. There are so many ways you could do this that nobody can give you a simple answer. Do you have a decided upon implementation? We might be able to give you an estimate on how fast your implementation will run. How are you bringing the data into the NIOS? What TCP/IP stack are you using?
Jake
