17 years agoMax Nios input speed?
What is the max speed the data can be feed into the Nios and then sent out on the ethernet? Thank you in advance.
17 years agoYou're right, that is very slow. I can tell you that I'm able to achieve ~40Mbit/s over the ethernet. I've also been able to do ~300Mbit/s using USB. So you are nowhere near the physical limitations.
So how have you got your tasks prioritized in uCOS/II. Is it possible that your task that samples the data simply isn't running frequently enough. My personal approach to this would be to write a little hardware module to sample the data and store it into the FIFO, then have the NIOS come and grab large chunks of data and send it off. Jake
