17 years agoMax Nios input speed?
What is the max speed the data can be feed into the Nios and then sent out on the ethernet? Thank you in advance.
17 years agoI am sending the output from a multiplexer to the Nios. At the moment I am sampling the the multiplexer at 100Hz / 8. (8 Channels)
The Nios is then connected to the PC via ethernet, using the mirco os or whatever it is called. I have two sockets open, one to send data and one to recieve commands. When tryign to increase the sampling rate, >200Hz my server on the pc crashes becasue data is missing on the input, i guess being lost in the Nios. Any ideas? I guess my limited sampling rate must be 200Hz. Is this correct as seems slow?
