11 years agoMax 10 unused VREF's
In the Pin Connection Guidelines sheet for the Max 10 they specify to connect unused VREF pins as defined in QUARTUS II software. I assume that they are referring to the Pin Assignment Tool. Could someone please elaborate on this. Thanks in advance.
The Pin Connection Guidelines are actually referring to the automatically generated .pin file. It will give you information like:
Pin Name/Usage : Location : Dir. : I/O Standard : Voltage : I/O Bank : User Assignment ------------------------------------------------------------------------------------------------------------- RESERVED_INPUT_WITH_WEAK_PULLUP : A2 : : : : 8A : RESERVED_INPUT_WITH_WEAK_PULLUP : A3 : : : : 8A : RESERVED_INPUT_WITH_WEAK_PULLUP : A4 : : : : 8A : RESERVED_INPUT_WITH_WEAK_PULLUP : A5 : : : : 8A : RESERVED_INPUT_WITH_WEAK_PULLUP : A6 : : : : 8A : VCCIO8A : A7 : power : : 1.8V : 8A : RESERVED_INPUT_WITH_WEAK_PULLUP : A8 : : : : 8A : RESERVED_INPUT_WITH_WEAK_PULLUP : A9 : : : : 8A : RESERVED_INPUT_WITH_WEAK_PULLUP : A10 : : : : 8A : RESERVED_INPUT_WITH_WEAK_PULLUP : A11 : : : : 8A : GND : A12 : gnd : : : : - Altera_Forum
You can actually set the unused pins as "Input tri-stated with weak pull-up" from Quartus II setting Goto "Device and Pin Options" -->Unused Pins --> Reserved all unused pins: As input tri-stated with weak pull-up" Here is the link from Altera can be your reference: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10192006_240.html - Altera_Forum
I believe it would great if you could first refer to the .pin file on the connection for the unused Vref pin.
Hi CATastrophe,
When and where is this file generated? Thanks - Altera_Forum
Hi mattschwende,
The .pin file will be generated after completion of the Fitter compilation. - Altera_Forum
Ok thanks got it
