11 years agoMax 10 unused VREF's
In the Pin Connection Guidelines sheet for the Max 10 they specify to connect unused VREF pins as defined in QUARTUS II software. I assume that they are referring to the Pin Assignment Tool. Could so...
11 years agoHi,
You can actually set the unused pins as "Input tri-stated with weak pull-up" from Quartus II setting Goto "Device and Pin Options" -->Unused Pins --> Reserved all unused pins: As input tri-stated with weak pull-up" Here is the link from Altera can be your reference: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10192006_240.html
