jAlter
10 months agoMAX 10. No 3.0 V Schmitt Trigger I/O standard
For some reason Max 10 doesn't support 3.0 V Schmitt Trigger I/O standard. Of course, using 3.3V I/O standard would work as well. But then Quartus would complain and would issue a fatal error if the...
FvM
10 months agoHi,
the missing link between above quoted datasheet table 8 (recommended Vi = -0.5 .. 3.6 V) and table 20 (Vih,max = Vccio + 0.3V) is the fact, that PCI clamp diodes are enabled in Quartus software for most IO standards by default.
You have to decide if your circuit involves possible input overshoot so that PCI clamp diodes must stay enabled to protect the FPGA or if they can be explicitely disabled.
