jAlter
10 months agoMAX 10. No 3.0 V Schmitt Trigger I/O standard
For some reason Max 10 doesn't support 3.0 V Schmitt Trigger I/O standard. Of course, using 3.3V I/O standard would work as well. But then Quartus would complain and would issue a fatal error if the...
FvM
10 months agoHi,
3.0 V input level is no problem with 2.5 V IO standard as there's no VCCIO clamp diode involved (unless explicitely enabled). Datasheet specifies recommended input voltage range -0.5..3.6 V independed of VCCIO. Vil and Vih depend of course on VCCIO, thus asymmetrical threshold can be a concern.
Frank
