MAX 10 JTAG programming
I know I am not directly answering your question, but ..........
I was wondering if you were reliant on the JTAG pullups for a logic high, or if you're using push-pull MCU outputs. I would strongly recommend using push-pull for the clock if nothing else.
If you're already doing this then I can't explain the issues you're seeing.
- Dan_Suciu1 year ago
Hello Mike,
Thank you for your reply. Definitely the signals rise/fall time and levels are very important.
I have the micro-controller with pins outputs push/pull mode and the signals are shorter rise/fall time (approx. 10ns 10% to 90%), compared with USB Blaster used to program .pof file over the same JTAG interface.
The clock frequency I use is lower than used in Blaster, and the calculated delays when generating .svf file, should be longer than required.
I was able to generate a version of the .svf file doing only erase and verify the blank memory using the Blaster.
Thank you anyway,
Dan
