MAX 10 dev board with USB Blaster JTAG Issues
Hello, first time poster here. I have a MAX10 dev board using a 10M50DAF484C6GES. I have been struggling to create just a sample build with the correct pinout that doesn't seems to kill the JTAG interface. Whenever I program the device, it would seem something happens where the FPGA is held in reset, or the JTAG pins are getting scrambled.. or something. I am assuming it's related to incorrect pin constraints.
This is the guide I am using: https://www.mouser.com/datasheet/2/612/ug_max10m50_fpga_dev_kit-1299798.pdf
When I constrain the CPU_RESETn correctly, it does seem to work. It even lets me program it repeatedly, although if I delete it from the list, it can't be discovered on the chain again. But if I constrain the CLK inputs, it seems to make it not work at all.
I guess I am not quite sure what the JTAG interface even needs on this thing. The example .sof files I am using work fine.
Any guidance would be great! Thanks
- FakhrulA_altera
- Parkerman1700
Hi! Thanks for getting back. You can mark this as solved, I believe the issue was related to a mismatch of I/O standard on the pin constraints. When the FPGA got programmed, some incorrect I/O standard somewhere was freezing the FPGA and causing the JTAG interface to fail in some way.
Thanks!
- FakhrulA_altera
Hi Parkerman1700,
Could you elaborate in details what is the real isssue here? As a start please refer to the following documents:
Intel® MAX® 10 FPGA Configuration User Guide
MAX® 10 FPGA Device Family Pin Connection Guidelines
Fakhrul
