Parkerman1700
1 year agoMAX 10 dev board with USB Blaster JTAG Issues
Hello, first time poster here. I have a MAX10 dev board using a 10M50DAF484C6GES. I have been struggling to create just a sample build with the correct pinout that doesn't seems to kill the JTAG inte...
Parkerman1700
1 year agoHi! Thanks for getting back. You can mark this as solved, I believe the issue was related to a mismatch of I/O standard on the pin constraints. When the FPGA got programmed, some incorrect I/O standard somewhere was freezing the FPGA and causing the JTAG interface to fail in some way.
Thanks!
