9 years ago
MAX 10 and the STAPL byte-code player
Hi
I'm trying to port the STAPL byte-code player to and stm32f2xx mcu. but i'm not having much luck.
I have connected 4 GPIO pins from the MCU to the JTAG pins on the MAX 10 FPGA, TCK TDI TDO TMS.
When i analyze the pins I can see some activity but not much on the TDO pin. And the jbi_execute returns with and exit_code 6 ("Unrecognized device")
any good ideas for what I',m doring wrong?
    Wow, thank you so much for the quick reply. Ill see if i can get it to run. Thanks!
    Hi
    It's been 6 month since i last looked at this code. It was just made as a proof of concept, we decided to go with a solution without an FPGA in the final product.
    But i have attached the test code that i got running. It's just the source files, it's made with the std_Periph library from ST.
    Hope it helps
    Hey Nikon,
    would you mind sharing your code with us?
    Thanks!
    Hi
    Yes, I got it to work after many hours ;)
    I will see if I can find the code when I get in the office tommorow, I will give to you to try
    I am also facing the same problem. I am trying to configure MAX 10 using linux machine through gpio. I also got the same error (Exit code 6: Unrecognized device).
    Did you got any sollution.
