magdalenastaszkiewicz's avatar
4 years ago
Material Declaration
Dear Sirs,
below, attached, I am sending a material declaration that I was able to download
from your website. Unfortunately, for the 5AGXFB5H4F35I3G element, the substance
Silica appears in the Laminate support - cas number 7631-86-9. Then with the same cas number 7631-86-9 there is the substance Silicon dioxide (SiO2). Then Silicon dioxide (SiO2) occurs with cas number 60676-86-0. Can I ask for verification and sending the correct declaration?
The second request is looking for a material declaration for the element:
WGI210IT S LJXT There is a downloadable file on the website, but there is not much data in it.
Thank you in adavnce.
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
    Thank you.
    AqidAyman_Altera
    Hi Magdalena,
    For the information of the declaration for the element: 5AGXFB5H4F35I3G, I still waiting for the updates from the respective team. I will give you the new updates about it when I got from them as soon as possible.
    For the material declaration of the element: WGI210IT S LJXT, the document you obtained from the link is all that have. For more details, I would suggest you post the request in Ethernet Products - Intel Communities. I hope this helps you get more details about it.
    Aqid Ayman
      AqidAyman_Altera
      Hi Magdalena,
      Thank you for your patience. Here is the update for your first question regarding the material declaration for the 5AGXFB5H4F35I3G element.
      For your information, both CAS numbers are correct because they are two different types of chemical forms with the same chemical formula (SiO2). You can refer to the attached datasheet to see the difference among various cas numbers for the same chemical formula.
      • CAS number 7631-86-9 Silicon dioxide, also known as Silica
      • CAS number 60676-86-0 Silica, vitreous
      Hope this clarifies your query.
      Aqid Ayman
  • Thank you very much for your help and I am waiting for information about the declaration for
    the element: 5AGXFB5H4F35I3G.
    As for the declaration for the element: WGI210IT S LJXT, there is not much data in it.
    I mean weight and cas number. So I am to understand that you do not have another declaration?
    Thank you for your help.
    AqidAyman_Altera
    Hi Magdalena,
    Thank you for reaching out to Intel FPGA Community.
    For your first request, I understand your issue. I will do the verification with the internal team and get back to you once I got the answer.
    For your second request, you can obtained the material declaration for the requested element through the link below:
    Intel® Ethernet Controller I210-IT
    Aqid Ayman
