Material Declaration
Hi Magdalena,
For the information of the declaration for the element: 5AGXFB5H4F35I3G, I still waiting for the updates from the respective team. I will give you the new updates about it when I got from them as soon as possible.
For the material declaration of the element: WGI210IT S LJXT, the document you obtained from the link is all that have. For more details, I would suggest you post the request in Ethernet Products - Intel Communities. I hope this helps you get more details about it.
Aqid Ayman
- AqidAyman_Altera4 years ago
Hi Magdalena,
Thank you for your patience. Here is the update for your first question regarding the material declaration for the 5AGXFB5H4F35I3G element.
For your information, both CAS numbers are correct because they are two different types of chemical forms with the same chemical formula (SiO2). You can refer to the attached datasheet to see the difference among various cas numbers for the same chemical formula.
- CAS number 7631-86-9 Silicon dioxide, also known as Silica
- CAS number 60676-86-0 Silica, vitreous
Hope this clarifies your query.
Aqid Ayman
