Marking codes of CY10CL040YF484
please see the attached images and inform whether these devices are faulty or good brought from MOUSER electronics and other vendor.
we are facing issue unable to do JTAG program and if AS mode program done then execution problem.
please suggest what is the problem.
- FakhrulA_altera
Hi Suvarna,
Thank you for providing the device photographs.
Both devices show the same ordering code, 10CL040YF484I7G, but have different corporate logos and trace/lot markings. These visual differences alone are not sufficient to determine whether a device is faulty or counterfeit.
For devices purchased directly through Mouser’s authorized channel, please retain the invoice and packing-list traceability. For devices from the other vendor, please confirm that the supplier is an authorized distributor and request its certificate of conformance or traceability documents.
The reported JTAG and Active Serial symptoms do not by themselves indicate a device defect. Please perform the following checks:- Run JTAG Auto Detect/read the device ID and provide the complete Quartus Programmer log, Quartus version, download-cable model, and JTAG frequency.
- Verify the FPGA power rails, JTAG signal integrity, Bank 1 VCCIO/reference voltage, MSEL settings, nCE, nCONFIG, nSTATUS, and CONF_DONE.
- For AS operation, verify the programming file and flash-device selection, as well as the nCSO, DCLK, ASDO, and DATA0 connections.
- If possible, test both units on the same known-good board with the same programming file and cable.
If the Mouser units consistently fail while a known-good lot passes under identical conditions, please contact Mouser for RMA support.
Fakhrul- suvarna
New Member
Dear Sir,
Please find the attached schematic
The cards in which JTAG error is coming in that TDO is not coming. in this card CONF_DONE pin always high and NCSO is "LOW" after programming in AS mode and NSTATUS is LOW. NCONFIG once program started its becoming LOWfor some time and then HIGHuntill proram and after Program over in AS mode.
and in working cards NSTATUS during Program LOW and after Program over it is HIGH. CONF_DONE is during Program LOW and after Program over it is HIGH. NCONFIG once program started its becoming LOW for some time and then HIGH untill proram and after Program over in AS mode.
please see my previous mail attached schematic and please see images attached . in working card DEVICE ID is coming and in bad card direct its telling JTAG error.
VCCIO bank1 voltage is 3.3V only and VREF pins i am using them as i/o pins.
MSEL setting "0010" and nCE grounded with 10k resistor and connected to programmer 6th pin. with same download cable and same program i am loading in to good card and bad card.
TCK freq is 6MHZ waveform attached.
Suvarna
