18 years ago
M4K memory problem in cyclone II 35672c6 device,
Dear Frineds,
when i am targetting a simple dual port memory for m4k, quartus 7.1 gives this error,
if target for LC's no problem, but i need more logic for my design, so targetting M4k is important, any help reagarding this is appreciated, i tried many data sheets and errta sheets.
regards
baba
Quartus II
Full Compilation was NOT successful (16 errors, 132 warnings)
확인
Info: Instantiated megafunction "sld_hub:sld_hub_inst" with the following parameter:
Info: Parameter "SLD_HUB_IP_VERSION" = "1"
Info: Parameter "SLD_HUB_IP_MINOR_VERSION" = "3"
Info: Parameter "SLD_COMMON_IP_VERSION" = "0"
Info: Parameter "N_NODES" = "2"
Info: Parameter "N_SEL_BITS" = "2"
Info: Parameter "N_NODE_IR_BITS" = "5"
Info: Parameter "NODE_INFO" = "0000110000000000011011100000000000010001000100000100011000000000"
Info: Parameter "COMPILATION_MODE" = "1"
Info: Parameter "DEVICE_FAMILY" = "Cyclone II"
Error: WYSIWYG RAM primitive "ram_block2a0" must have Port A, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a0" must have Port B, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a1" must have Port A, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a1" must have Port B, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a2" must have Port A, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a2" must have Port B, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a3" must have Port A, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a3" must have Port B, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a4" must have Port A, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a4" must have Port B, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a5" must have Port A, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a5" must have Port B, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a6" must have Port A, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a6" must have Port B, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a7" must have Port A, Address port or parameter specified
Error: WYSIWYG RAM primitive "ram_block2a7" must have Port B, Address port or parameter specified
    Hey there,
    sorry for the late response, but actually I couldn´t restore the old problem anymore. I don´t know wether this has something to do with it or not, but I was using Quartus at the 7.x edition and I´m still using it. What the main difference between the two times I´ve created that type of structure was:
    I´ve resolved the problems between my pipeline and the Avalond ST interface _before_ I´ve inclueded the pipeline into the SOPC builder _and_ told it to automatically insert timing adapters.
    Hope that this might help someone with the same problem.
    Greetings,
    Kjellski
    Hello Brad,
    it seems I´ve solved the problem. Not the problem itself, but my problem.
    I´ve just rebuild the design in SOPC-Builder and added my components as I did before. I´ve just not played arround with addings and things like before, just because now the way to go was a bit more clean...
    But after that, the sythesis went through...
    I can look up the module in hirarchy, maybe for the next guy with this problem. Just have to wait until monday...
    Greetings
    Kjellski
    Are the entity names like ram_block2a0 created during synthesis with the errors locating to code in the db directory? If so, look for a problem higher in the hierarchy.
    Hello Altera Gurus,
    I´ve got the same problem as above... my first post here and I´ve already used the search and won´t open a new thread. Isn´t that amazing?
    Sorry... to the point:
    I´ve used a reference design for CycloneII NiosII Devboard and entered SOPC Builder. Then I wrote my wrapper to connect my pipeline like this:
    Avalon MM -> ST -> Pipeline -> Avalon ST -> MM
    Then I´ve handled some errors and resolved problems. The system generation was successfull and I´ve updated the block in the .bdf file. Reconnected some wires and started compilation...
    After about 900 Warnings the errors occured:
    The double click on one of this messages shows the following section:
    VARIABLE
        ram_block2a0 : cycloneii_ram_block
            WITH (
                CONNECTIVITY_CHECKING = "OFF",
                LOGICAL_RAM_NAME = "ALTSYNCRAM",
                MIXED_PORT_FEED_THROUGH_MODE = "dont_care",
                OPERATION_MODE = "bidir_dual_port",
                PORT_A_ADDRESS_WIDTH = 11,
                PORT_A_BYTE_ENABLE_MASK_WIDTH = 1,
                PORT_A_BYTE_SIZE = 1,
                PORT_A_DATA_WIDTH = 1,
                PORT_A_DISABLE_CE_ON_INPUT_REGISTERS = "on",
                PORT_A_DISABLE_CE_ON_OUTPUT_REGISTERS = "on",
                PORT_A_FIRST_ADDRESS = 0,
                PORT_A_FIRST_BIT_NUMBER = 0,
                PORT_A_LAST_ADDRESS = 2047,
                PORT_A_LOGICAL_RAM_DEPTH = 2048,
                PORT_A_LOGICAL_RAM_WIDTH = 32,
                PORT_B_ADDRESS_CLOCK = "clock1",
                PORT_B_ADDRESS_WIDTH = 11,
                PORT_B_BYTE_ENABLE_CLOCK = "clock1",
                PORT_B_BYTE_ENABLE_MASK_WIDTH = 1,
                PORT_B_BYTE_SIZE = 1,
                PORT_B_DATA_IN_CLOCK = "clock1",
                PORT_B_DATA_WIDTH = 1,
                PORT_B_DISABLE_CE_ON_INPUT_REGISTERS = "on",
                PORT_B_DISABLE_CE_ON_OUTPUT_REGISTERS = "on",
                PORT_B_FIRST_ADDRESS = 0,
                PORT_B_FIRST_BIT_NUMBER = 0,
                PORT_B_LAST_ADDRESS = 2047,
                PORT_B_LOGICAL_RAM_DEPTH = 2048,
                PORT_B_LOGICAL_RAM_WIDTH = 32,
                PORT_B_READ_ENABLE_WRITE_ENABLE_CLOCK = "clock1",
                POWER_UP_UNINITIALIZED = "false",
                RAM_BLOCK_TYPE = "AUTO"
        ram_block2a1 : cycloneii_ram_block
            WITH (
                PORT_A_FIRST_BIT_NUMBER = 1,
                PORT_B_FIRST_BIT_NUMBER = 1,
        ram_block2a2 : cycloneii_ram_block
            WITH (
                CON
    And so on, doesn´t seem that there are different things missing...
    Maybe you can give me a tip how I can resolve that problem.
    [EDIT]
    Or please, tell me what informations you need to help out...
    [/EDIT]
    Yours and a preventive thanks,
    Kjellski
    It sounds like a megafunction is being instantiated with incorrect(or missing) parameters. Without any extra information, including the file, it's impossible to tell. If you want someone to look at it specifically, I would file an SR.
    Has there been a resolution to this problem? I'm getting the same error. I've just used the megawizard to create a Verilog module and call that in other modules and it gives me this error.
    Did you use the megawizard and then instantiate the output file? Are you synthesizing in Quartus? The error message basically says its not finding a required parameter, so how are you passing this parameter in? (You don't manually do this, the megawizard adds this and then you usually instantiate that file.)
