18 years agoM4K memory problem in cyclone II 35672c6 device,
Dear Frineds, when i am targetting a simple dual port memory for m4k, quartus 7.1 gives this error, if target for LC's no problem, but i need more logic for my design, so targetting M4k is i...
18 years agoDid you use the megawizard and then instantiate the output file? Are you synthesizing in Quartus? The error message basically says its not finding a required parameter, so how are you passing this parameter in? (You don't manually do this, the megawizard adds this and then you usually instantiate that file.)
