8 years agoM20K block related build error
I try to build the opencl code. The memory blocks in estimated resource usage summary is 35%. But there is a error message as below: Error (170048): Selected device has 2713 RAM location(s) o...
8 years agoHi mattsai,
No sure which Quartus version you are using. I think you need to check at the latest Quartus version Fitter Resource Usage Summary report to know the numbers of M20K RAM that is being use. The attached screen shot shows the numbers of M9K RAM utilization. Regards, nyusof (This message was posted on behalf of Intel Corporation)
