hariprasathb's avatar
hariprasathb
6 months ago
LVDS TX/RX Pin Assignment Error in Quartus – Unable to Resolve
Hi Team,
I am facing a pin assignment issue with LVDS TX and RX IP in Quartus Prime.
I have tried all the suggestions provided earlier (bank selection, I/O standard, refclk, PLL connections, and pin constraints),
but I am still encountering pin assignment errors during compilation.
Details:
- Device: AGIB022R31A2I2VB
- Tool: Quartus Prime 25.1.1
- LVDS IP: TX and RX
- Mode: External pll mode in both TX and RX
- Issue: Pin assignment errors related to LVDS TX/RX signals
I have verified:
- Correct I/O banks and VCCIO
- Differential pair placement
- Dedicated reference clock usage
- PLL lock status
Despite this, the issue persists.
I have attached all relevant files:
- .qsf
If possible, could someone please:
1. Review the attached files and point out what might be wrong, OR
2. Share a small working reference project for LVDS TX/RX pin assignment
I am also open to discussing this over a call if needed, as it may be easier to debug.
Any guidance would be appreciated.
Thanks & Regards,
Hari
  • Farabi_Altera's avatar
    Farabi_Altera
    Let me check and get back to you.
    regards,
    Farabi
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Hi Hari,
    Can you share .qar files for me to reproduce the error from my end?
    I did not see it. If possible, you can share it through Private Message.
    Aqid
    AqidAyman_Altera
    Hi Hari,
    Can you try to remove all the pin assignments?
    If this passes the compilation, then you should follow the pin placement suggested by the fitter, and then it should be good.
    It might be the issue with your differential pin and PLL pin placement. Refer guideline below:
    https://docs.altera.com/r/docs/721819/25.3.1/agilextm-7-lvds-serdes-user-guide-f-series-and-i-series/pin-placement-for-differential-channels
    Aqid
  • sstrell's avatar
    sstrell
    You may also want to try out Interface Planner.  That will help ensure you can pick legal locations:
    https://docs.altera.com/r/docs/683143/25.1.1/quartus-prime-pro-edition-user-guide-design-constraints/using-interface-planner
