LVDS Serdes
Hi-
Serdes input is 40 bits.
Read this 40bit from ROM and enter it into Serdes
"101010.....1010" It's okay
if you type it like this "00000000000000000000000000000111111111111111111111" If you enter this way, the following waveform appears.
I'm use 2GHz Serdes
How to make 00......000 flat, 111....11 flat
- AGORS5
Are you using Dev kit or own hardware ?
I am asking cause it looks like cold junction between chip and PCB.
So called head-on-the-pillow issue.
In other words , there is no connection between fpga and pcb.
There is samall capacitance between fpga ball and pcb - few pF.
That's why you can see spikes instead of square wave.
Try with other pin on the same chip or another unit.
Best regards
Adam Górski
- AqidAyman_Altera
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- AqidAyman_Altera
Thank you for reaching out Intel FPGA Community.
Which device are you use?
