17 years agoLVDS and Cyclone II Nios DEV Kit
Hello, Currently I use Nios II development kit with EP2c35 device. Also this kit contains Prototype connectors (Proto1 and Proto2). Can I use some I/O pins of this connectors as differentia...
17 years agoFvM,
Thank you very much for the response. I've got more additional questions very important for me. I have a core, this is a master of a 4-bit wide bus ( Pclk, synch, TX, RX). PCLK is 8MHz. I want to use Cyclone II I/O LVDS differential mode for them. Is it just enough to set LVDS standard in the appropriate column of the Pin Planner or I should use special primitives? Is there some application notes with examples how to use LVDS signalling with ALtera FPGA. And the second question, what blocks can I use if TX should be tri-stated? It’s used to allow the transmission of data by multiple sources in adjacent timeslots without the risk of driver contention. Thank you.
