16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoThats why i want your advise because you are an fpga specialist.I want to make my code more efficient in order to expand it for future work in which i will may want to use a bigger image.For example an 60x60 image may wont even work with this kind of code because of the big use of resources.Thank you
