16 years agoLOW Power VS. DUAL-EDGE TRIGGERED FLIP-FLOPS
Hi !guys, the book Advanced FPGA Design by STEVE KILTS says DUAL-EDGE TRIGGERED FLIP-FLOPS can help reduce power. this is his refernce code: module dualedge( output reg data...
15 years agoSorry this came rather late. Anyway, just for those of you who wish to implement dual-edge FFs, here's a simple VHDL example (there are a few others - I know another implementation that works as well):
dualEdgeTriggered: process(reset,clk) is
variable q1,q2:std_ulogic_vector(q'length-1 downto 0);
begin
if reset='1' then q1:=(others=>'0'); q2:=(others=>'0');
elsif rising_edge(clk) then q1:=d xor q2;
elsif falling_edge(clk) then q2:=d xor q1;
end if;
q<=q1 xor q2;
end process;Not sure if this still works, but I've had success with this before. Regarding power consumption, yes you will generally have more gates, but doing this *could* save you from creating another higher speed clock that's double the rate, which will of course draw much more power.
