AGaru1
6 years agoLow Latency 100G Ethernet Intel FPGA IP Hardware Design Example
Hi everyone,
I want to create a loop between 2x Low Latency 100G Ethernet Intel FPGA IP Hardware Design Example on a Stratix 10 MX. The main idea is to implement the entire example design described in alt_e100s10.v twice inside a top level module. The only doubt is given by the avalon jtag master bridge. Can i instantiate two of them, one for each instance? And if not, can i use the Ethernet Link Inspector for the two different instances with only 1 avalon jtag master bridge?
If i was not clear enough, please ask me questions.
Thank you.
