14 years agoLoss of FPGA configuration
To minimize power consumption, I have the Oscillator input of the main part of my Stratix III design gated (glitchfree keeping low, if gated). Connected to this clock (50 MHz) are two synchron...
14 years ago --- Quote Start --- However: I still observe significant power supply dip on VCCL(1.1V) and VCCPD (2.5V) when activating the reset (without clock gating), and I assume the POR did just not trigger (but may do so on another device...). Maybe I have some illegal bank voltage combination (did check that, but found no offending conditions so far)? --- Quote End --- The observation seems to suggest, that the suspected power supply drop below reset threshold happens at internal nodes (PLL and core supply) and not peripheral supply, as I previously guessed. This changes the picture. I wonder, if the current transient may be normal operation and the voltage drop primarly a board hardware problem. To get clarity about the effect, I would either measure the respective supply rail dynamic current or check the power supply transient response with a test load.
