15 years agoLoop index overflow problem
Hi there,
I've wrote a little VHDL program in Quartus II. I'd like to separate one big std_logic_vector into small fix-length std_logic_vectors and the compile told me that the index is out of range, very strange... source code: =================================================== load_p:process(i_clk,i_datain) variable p_count:integer range 0 to 8*8*i_width; --i_width is a constant variable p:std_logic_vector(i_width-1 downto 0);--buffer of one data begin p_count := 8*8*i_width-1; --counter for index for i in 0 to 63 loop p := datain(p_count downto p_count-i_width+1); --buffering (line 30) p_count := p_count-i_width; --get next line index end loop; end process; ======================================================= the compiler says: Error (10528): VHDL error at df_loader_p.vhd(30): value "-1" is outside the target constraint range (0 to 512) Help me out , thx!!!:(21 Replies
--- Quote Start --- Ok - It was because you had included the clock in the sensitivity list and not used it - it is a common newbie mistake. --- Quote End --- i think at the synthesis phase, the compile actually add all the signals to the sensitive list. - Altera_Forum
You have changed the constraint range - in the origional code you posted :
variable p_count:integer range 0 to 8*8*i_width; --i_width is a constant Which should give you 0 to 512. - Altera_Forum
ok, then i 've changed the P_count to increasing order, problem still...
p_count := 0; --counter for index for i in 0 to 63 loop p := datain(p_count+i_width-1 downto p_count); --buffering p_count := p_count+i_width; --get next line index end loop; and the compiler says: Error (10528): VHDL error at df_loader_p.vhd(30): value "512" is outside the target constraint range (0 to 511) T.T - Altera_Forum
--- Quote Start --- Then your design is very flawed. It is not going to produce synchronous logic because you have not included the clock inside your process. --- Quote End --- :D, no ,i use two processes method, this is only the combinational part, i have deleted the sequential part... - Altera_Forum
--- Quote Start --- no, it's a small single component in a big system --- Quote End --- Then your design is very flawed. It is not going to produce synchronous logic because you have not included the clock inside your process. - Altera_Forum
Or you could start Pcount at its upper bound and just change the datain extraction.
--- Quote Start --- Another question - is this testbench code? --- Quote End --- no, it's a small single component in a big system - Altera_Forum
--- Quote Start --- The code does exactly what you have written. In the last iteration, it tries to decrement p_count from 7 to -1, although everything is finished. Instead of decrementing a variable, you may want to calculate the p_count value at the entry of each iteration. --- Quote End --- Hi, thx for reply, i don't really understand what is your suggestion means...you mean i have to unroll the iteration? and i think you'er right about the iteration , that after the "last" iteration (i=63), the i continue increasing to 64, like C language or any other program language, but with the entry constrain , the procedure in the iteration shouldn't be executed... i think i have to loose the constrain of the range of p_count to -1 to 8*8*i_width... - Altera_Forum
