17 years ago
Logic lock
How to make many logic locks that are exactly the same as one logic lock?
    --- Quote Start ---
    how to import one design partition 100 times using tcl script?
    Thanks!
    --- Quote End ---
    Hi sylvest,
    do you think you will go with the partiton based flow ? I have to look for a way with a TCL sccript, because I have use the flow actual only with a few, but larger blocks. I don't know how full your FPGA will be with all the multiplier, but at a high uitiliaztion in would be more difficult to find a fit for your design with the hard requirement to preserve the placement and the routing. BTW that is also a advantange of the partition flow, because you can choose between serveral options ( Placement and Routing, Placement, Netlist ).
