--- Quote Start ---
how to import one design partition 100 times using tcl script?
Thanks!
--- Quote End ---
Hi sylvest,
do you think you will go with the partiton based flow ? I have to look for a way with a TCL sccript, because I have use the flow actual only with a few, but larger blocks. I don't know how full your FPGA will be with all the multiplier, but at a high uitiliaztion in would be more difficult to find a fit for your design with the hard requirement to preserve the placement and the routing. BTW that is also a advantange of the partition flow, because you can choose between serveral options ( Placement and Routing, Placement, Netlist ).
