16 years agolittle question about VHDL
Hi,all, I want to ask is it costs a lot of resource or time delay to determine when using the sentence "if (vir+M)>500 then" ,here vir and M are both integer type. Thanks in advance.
16 years ago --- Quote Start --- FPGA logic array blocks are usually handling the add/sub/compare operations. Cyclone family has no add function with it's embedded multipliers. Stratix has multiply/add combinations, but it would be rarely used for simple add operation, I think. --- Quote End --- Hi ,FvM,again.;) So,what do you think the cyclone will do adder calculation when we use adder/multipliers?Just a lot of luts and dsp block?
