17 years agoLeaving target processor paused
When I try to run simple hello_led project using CII_Starter_NIOS.sof and corresponding .ptf file I get the following error and nothing happens next:
Verifying 00400000 ( 0%) Verify failed between address 0x400000 and 0x4000D3 Leaving target processor paused What is the cause of this error? Thanks4 Replies
Please try a search on the forum for other posts regarding your same problem as this question has been answered many times before.
Jake - Altera_Forum
So what exactly I need to do? Where do I need to connect it and what time constraint should be met?
I have QuartusII web edition so will I be able to change the settings? Thanks for the HELP! Best Regards, Nishant - Altera_Forum
This typically occurs when your memory interface is not working properly (usually because you've not connected it properly or it's not meeting timing constraints).
Jake - Altera_Forum
i've encounterred this problem , maybe there's something wrong with your memory module . if you use a sdram , check the clock phase and settings of the sdram controller. good luck to you
