17 years agoLeaving target processor paused
When I try to run simple hello_led project using CII_Starter_NIOS.sof and corresponding .ptf file I get the following error and nothing happens next: Verifying 00400000 ( 0%) Verify failed be...
17 years agoHi,
i've encounterred this problem , maybe there's something wrong with your memory module . if you use a sdram , check the clock phase and settings of the sdram controller. good luck to you
