17 years agoLeaving target processor paused
When I try to run simple hello_led project using CII_Starter_NIOS.sof and corresponding .ptf file I get the following error and nothing happens next: Verifying 00400000 ( 0%) Verify failed be...
17 years agoThis typically occurs when your memory interface is not working properly (usually because you've not connected it properly or it's not meeting timing constraints).
Jake
