16 years agoJtag Working Wrong!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hi everybody!
Recently,I'm debug a board about Ep2c8 which build by myself,after I welding end all devices, I made a sample test program and download it with QuartusII8.0. Then Quartus tell me download success! But I find that fpga does't work as my test program!My test program just make fpga's some pins output as low! As a result ,all pins output as a high! So ,Someone who know about it ,please tell me why!! Thank you very much! Shenhuan 2009-11-22:confused:11 Replies
Thanks for your advice!
My board work now,there are something about nCS pin,because the problem of welding,nCS pin hasnot been pull down to ground! - Altera_Forum
The only cause I can see is that an error occured during the FPGA configuration, but it's strange that Quartus doesn't detect it.
There could also be a problem with one of the power supplies or a bad decoupling but I'm not sure it would prevent the COND_DONE pin from going high. Do you have another design that you can test? - Altera_Forum
Yes! Is there something others may cause this?
CONF_DONE should be high after the FPGA has been programmed. Do you have an external pull-up on the pin?
nCONFIG is high and CONF_DONE is low
! - Altera_Forum
I meant the JTAG hardware configuration in Signaltap.
What are the levels of the nCONFIG and CONF_DONE pins after configuration? - Altera_Forum
Yes!QuartusII show me download success!
Did you setup the JTAG hardware correctly in Signaltap? Does it find your FPGA?
SignalTap can build and download ,but when i run it ,it show me that jtag communication error!
What do you mean by "signalTapII does't work"? What's the status of the CONF_DONE pin?
