14 years agoJTAG target board circuit design
Hello, Im trying to program an epm7064s fpga jlead package device. I am using the USB blaster which is integrated into the terrasic micro max II development board. I am using a PLCC socket with 44...
14 years agoleon_heller,
Thank you for the circuit diagram, I definitely haven't tried this configuration. I've used slightly different values on the pull ups and pull downs and I certainly didn't connect a clock to any of the clock inputs (the major discrepancy I suspect). I see that circuit was for the epm570 but it sounds like you have used the same circuit for the max7000. I will give this a try. Thanks a bunch, Chuck
