12 years agoJTAG programming successful but no output on hardware
I am using a Cyclone III EP3C10F256 device. When I connect the USB Blaster and run the JTAG programmer in Quartus, the programming is done with no error. The code is just written to tie a few outputs...
12 years agoI found the problem. The CONF_DONE pull-up resistor was connected to a 1.2V supply instead of 3.3V (which was the supply of the bank). Therefore, after the programming is finished, the FPGA still stays in configuration mode with 1.2V. I changed the pull-up voltage and the problem was solved. Thanks you very much for your help.
