16 years agoJTAG Configuration on EP3C120F780 program loss
Hi All, i need help. I am having a problem with my board in which the configuration loss easily when handling the board. It is so sensitive that i had to re-program it everytime. From the hand...
16 years ago --- Quote Start --- Do you think the VREF will affect the configuration as i am using this pin as I/O pins --- Quote End --- It won't, very surely. --- Quote Start --- After program we will load the board to a rack manually. --- Quote End --- How do you "move it to a rack" without disconnecting the power supply and thus loosing the configuration?
