16 years agoJTAG Configuration on EP3C120F780 program loss
Hi All, i need help. I am having a problem with my board in which the configuration loss easily when handling the board. It is so sensitive that i had to re-program it everytime. From the hand...
16 years agoFirst of all thank for replying.
After program we will load the board to a rack manually. This is where the program loss. Sound weird. I am ruling out the unstable power supply because i have been monitoring the VCCQ for a while now. Do you think the VREF will affect the configuration as i am using this pin as I/O pins Input reference voltage for each I/O bank. If a bank uses a voltage-referenced I/O standard, then these pins are used as the voltage-referenced pins for the bank. [/I][/I] If voltage-referenced I/O standards are not used in the bank, the VREF pins are available as user I/O pins.[/I][/I]
