16 years agoJTAG configuration error in CycloneIII
Hi
The last week I wrote a post about a problem with the configuration of the EP3C5E144C8N cycloneIII FPGA: ------------- I´m trying to program a EP3C5E144C8N FPGA in JTAG mode using a ByteBlasterII cable. The pins are connected as indicated in the JTAG configuration of a single device using a download cable (Fig 10.24 of the Cyclone III handbook). All the power suplies used have been measured in the device and are OK. When I test the JTAG chain integrity the QuartusII return the messages: -No device detected -The TDO connection to the dowload cable migth be shorted to VCC or is an open circuit -The TCK and TMS connections to the last device migth have problem. --------------- After that ,I have done a lot of test and unfortunately I can´t solve the problem. I check the signals TDI, TMS and TCK and they are OK (signals transitions when I press Start in the IDCODE iteration test) but I dont´t have nothing in TDO, just 1V of DC (not the expected transitions). All the power voltages are OK in the respective pins. The exposed pad is connected to ground I´m using 2.5V as power supply of the ByteBlasterII cable. I have change the device and I have been very carefully with the ESD but nothing, the same error. I´m considering some error in my electric design, I attached a file with the design, maybe you can help me to find the error. Thanks a lot
