16 years agoJTAG configuration error in CycloneIII
Hi The last week I wrote a post about a problem with the configuration of the EP3C5E144C8N cycloneIII FPGA: ------------- I´m trying to program a EP3C5E144C8N FPGA in JTAG mode using a ByteBla...
16 years agoHi MSchmitt and Frank
Finally I found the error origin. As I suspected the configuration load failed because the soldering of the cycloneIII. As a last desperate resource I push down the component against the board and try to program and.. surprise!! it works.. I resolder again the component and now is fine. The surprissing part is that before of that, I checked pin to pin the continuity connection (without apply a big force) and it seemed OK, but not. Well, I´m more tranquil now. Thanks for your answers, I will use all your advices in the final design of my board Best regards
