16 years ago
JTAG can’t find device
Hi all,
I am a beginner of Altera's device.
Today, When I use the JTAG mode of Quartus’ programmer to configure the device EP3C5E144, the programmer always says “Unable to scan device chain. Can’t scan JTAG chain.”
When the programmer tried to scan the chain, I test the TDI, TDO, and TCK. There is data wave on TCK and TDI, but the TDO never changed and always hold about 2.2V.
All the power, 1.2V, 2.5V, 3.3V, is OK. I used 2.5V to power the JTAG connector, and added a 1k resistor between 2.5V and 3.3V (pin 6).
Besides, NCE holds 0V. Though I have pulled up the signals, Config_done and nstatus, they all keep 0.033V.
I also use a flash to configure the FPGA in AS mode. The programmer can download code to flash successfully, however the FPGA shows no action no matter I re-power up the system or not, and there is no clock on DCLK.
The Usb blaster should be right, because I can configure some other boards. Could anybody give me some suggestion?
