16 years agoJTAG can’t find device
Hi all, I am a beginner of Altera's device. Today, When I use the JTAG mode of Quartus’ programmer to configure the device EP3C5E144, the programmer always says “Unable to scan device chain. Can...
16 years agoThe Vccpd = Vccio1A = 2.5V
The program connector is powered by V_3.3 These should be the same (either V_3.3 or 2.5V). nSTATUS and nCONFIG and CONFIG_DONE should be pulled-up to Vccpgm, which is 3.3Vcc, not V_3.3. Maybe these are supposed to be the same, but in your schematic the labels differ. Pull-up JTAG to Vccpd. Pull-up other programming pins to Vccpgm. Good luck, Ton
