JESD204B Multi-Link configuration with Different Link Parameters on Stratix10
- 11 months ago
For a quick and straightforward start, I recommend creating three separate single-link instances first, and then integrating them into a single project. This approach should help simplify the initial setup and reduce potential integration issues.
Please let me know if you have any questions or need further assistance.
Hi Chee Pin,
As you mentioned, by duplicating the single-link example design and customizing it according to my configuration,do you mean that I should add additional JESD204B RX IP instances within the same Qsys (Platform Designer) file, or should I create three separate single-link example projects and then integrate them into a single project?
Which approach would be more suitable?
