I've a problem with PCIe in Arria10. Сoreclkout_hip = 0!
We have developed a module with installed FPGA Arria 10. FPGA - 10Ax022E4F29i3. In the project we use IPCore Pcie (HardIP). Refclk (100MHz) is detected inside FPGA (SignalTap "sees"). But on the output IPCore:
coreclkout_hip = 0; (!!!)
rx_is_lockedtoref = 0;
rx_is_lockedtodata = 0;
reset_status = 1;
But
serdes_pll_locked = 1.
So far I have not had such problems with HardIP PCIe.
Сoreclkout_hip was always available.
- AndyN
Sounds like you're just stuck in reset. What're the npor and pin_perst inputs to the IP doing?
- BoonT_Intel
AndyN, thanks for help.
Other than reset, what is the sampling clock that you used for signaltap (STP)? If the sampling clock is slower or same frequency compare to the coreclkout_hip. Then you might unable to see it toggling in STP.
- VMich4
we tried different varients for npor and perst... it doesn't works. And this poject on Altera KIT (Arria 10 GX115) works!
STP used diff. freq - 100 ref_clk from input, 62,5 MHZ from other pin. nothing.... And reset_status = 1!!
- BoonT_Intel
Hi sir,
Can you please elaborate on this sentence?
Does it mean ref clock is 100Mhz, other pin with 62.5Mhz is for which signal? And 'nothing' is referring to what?
